Mechanical key doesn't lock trunk
Old 08-28-2013, 11:10 AM
gpseymour's Avatar
2000 E320W 4Matic
I have only one key for my 2000 E320 (others on order), but my mechanical key doesn't double-lock the trunk. It works in the door and glove compartment, but doesn't turn the cylinder in the trunk, at all. Anyone had this experience?
Old 08-28-2013, 11:41 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Squirt some WD40 in the lock!!
Can you open the trunk with your key fob???
Old 08-28-2013, 12:34 PM
gpseymour's Avatar
2000 E320W 4Matic
Yes, the key fob works fine.
I'll give the WD40 a shot, but it doesn't feel stuck - it doesn't feel like it's even trying to move.
Old 09-01-2013, 07:50 PM
gpseymour's Avatar
2000 E320W 4Matic
No love with the WD-40. Anyone else have an explanation?
I'm starting to wonder if the trunk is keyed differently from the rest of the car for some reason...
wasp01amg (04-19-2016)
Old 09-01-2013, 09:43 PM
Plutoe's Avatar
1999 E300TD
If the metal key will easily slide into the lock yet not turn in the trunk lock either R or L, but yet open the drivers door, then I would agree with you that the trunk lock is keyed differently---------Have you never opened the trunk???
Old 09-02-2013, 04:29 PM
gpseymour's Avatar
2000 E320W 4Matic
I've never had any trouble opening it with the fob (though the console button seems finicky). I hadn't even thought to try the key until recently when I was valet parking, and wanted to double-lock the trunk, but was unable to do so.
Old 09-02-2013, 06:12 PM
Plutoe's Avatar
1999 E300TD
I am also very confused with this post------please quote from the owners manual your description/procedure for what you are calling "double locking"
Old 09-03-2013, 07:43 AM
gpseymour's Avatar
2000 E320W 4Matic
I don't have my manual in front of me. I'm talking about the manual locking (I think it's a turn to the right) that keeps the electronic key from being able to open the trunk.
Old 04-18-2016, 09:30 PM
R_Bzdel_E430's Avatar
2002 E430 4matic (W210)
I'm having the exact same issue. Can't rotate cylinder with the mech. Key. This car has had a past insurance claim, I gotta wonder if a trunk lid was swapped used in its entirety with no consideration for a mech. Key.
Which now begs the question, can a replacement be had that is keyed properly?, or will an entire lock set have to be purchased?
Old 04-18-2016, 11:38 PM
Never mind got it moving
Old 04-19-2016, 12:23 AM
raymond g-'s Avatar
99 E320
it's not easy to turn given the lack of leverage with the skinny metal footprint
of the key. it may require a little help (not too much) with pliers. DONT
OVERMUSCLE it if you do use a tool
Quick Reply: Mechanical key doesn't lock trunk
