2000 E320 fog lights
I had to remove the front bumper cover on my wagon and so had to disconnect the fog lights in the cover. These were quite "green" and no way to re-connect them. Where O where could I find the plug for the end of that harness? or the two pins or combination of both, I have a parts car but the lights are gone along with the ends. Anyone know if there is another harness that would have the same connector or where I could get two?
98 Brilliant Silver E320 Wagon
MB makes a fog light replacement harness kit but I believe you need to solder it in place. At some point, I believe, a connector was added. A little googling should get you the part no.
'15 S550, '10 E350 P1/P2, '02 ML320
I wrote this DIY a few years back when I needed to replace my melted foglight harness. Hope it helps!
https://mbworld.org/forums/attachmen...ht-harness.pdf
The dealer kit comes with a replacement connector for the cable where the foglight harness connects.
