Door Mirror gasket
2002 E55 AMG Obsidian Black with Charcoal
Door Mirror gasket
Has anyone found a replacement for the door mirror gaskets?
2000-2002 facelift cars?
I was thinking of trying to fit this reproduction gasket for the 1995-1999 pre-face lift cars:
http://www.atpartsmotor.com/index.ph...ail&pid=155234
OOOOOOOOOOOOOOOOOOOOOp's----was at a scrapper recently looking for gaskets and when I took the mirror assemblies apart one if the two mirror wiring harnesses had the gasket fused to the harness. I took the wiring harness with gasket for future use!!
My error in the post was that I therefore assumed that would be called out in EPC-----bad assumption as you point out it ain't!!
Plutoe,
Thank you.
I have checked my EPC. I can not find that wire harness as a separate item. Only part of the mirror "frame".
Do you have a reference number for the harness?
Thank you.
I have installed the new reproduction gasket today. I think the new parts are fantastic and recommend them.
Here is a link with my write up and pictures. It starts at entry number 14.
https://mbworld.org/forums/w210-amg/...ml#post6008171
2 weeks with the new gaskets/seals. No problems at all. The noise level at the driver's side door mirror is gone. The rubber looks great. I am very satisfied with this product.
