Replacing the transmission mount. 2000-E430
98 Brilliant Silver E320 Wagon
It's fairly easy. You need to support the transmission with a floor jack and block of wood. Loosen the support bracket bolts part way then remove the mount and replace with new one. I suggest the Lemforder as others have had complaints about URO parts.
DIY with torque specs can be found at http://www.benzworld.org/forums/w140...ion-mount.html
