::ECS Tuning:: W210 Propeller Shaft Flex Joint Kits
Former Vendor of MBWorld
2012 SLS AMG
Click HERE to order or for more information.
Kits Starting At - $186.00*
A critical component within the drivetrain that serves as a vibration and torsion damper, the flex discs bolted between the transmission output shaft and the propeller shaft as well as the propeller shaft and the differential, can wear significantly over time.
When the unit fails, damage to the underside of the car is unavoidable, and will certainly immobilize the vehicle.
Replacing the propeller shaft discs not only protects you from this disastrous prospect, but also greatly reduces driveline noise and harshness.
To make replacing propeller shaft flex discs easy, we offer these kits that include the front and rear discs as well as all of the hardware needed for installation.
What's more, these high-quality OE design kits are Genuine Mercedes-Benz parts or made by well know aftermarket manufacturers like Lemforder.
*Price subject to change.
