2001 e 320 needs help
2001 Mercedes Benz E 320
Hey folks im new and I was trying to figure out my problem is on my 2001 e 320 it cranks but no start unless I use starting fluid ounce it cranks the motor idles perfect until I press the gas I have a missfire on the right side of the motor it never goes over 3k rpm and it drops down in rpms as if it wants to cutt off and the check engine light flashes I have new spark plugs, wires, fuel pump, and front o2 sensors but my battery is on its last ride can anyone please help ?????
2001 E320 4matic Wagon
First, check current codes.
Clear if any.
Then try to start engine.
Start or not, check for codes.
If necessary, then do more research.
Clear if any.
Your battery is on its last leg? How are you starting it? Are you jumping it to start then removing the jumper cables? If you are not getting close to a steady voltage out of you battery, it can do what you are describing. The battery stablizes the voltage and cars will not run without steady voltage. Did this problem occur after your recent parts replacement on the car?
