Command Radio out
Old 08-17-2014, 05:27 PM
littlehandegan's Avatar
Gelandewagen
Command Radio out
2000 E55 Radio with nav has suddenly gone out on me.
Got out of car and went in my house for 15 minutes, came back out and turned car on and no stereo. No loud beep when turning car on, nothing.
However it will eject the nav CD.
Is it a fuse, or more in depth?
Old 08-17-2014, 09:44 PM
Gelandewagen
Where to find fuses?
Old 08-18-2014, 08:51 AM
cudaized's Avatar
2002 E55 AMG Obsidian Black with Charcoal
Loose connection somewhere?
Old 09-01-2014, 07:10 PM
Gelandewagen
We'll it has happened again. This time it hasn't come back on
What should I check?
It does still eject CD's, but nothing more.
Old 09-01-2014, 10:49 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Pull the radio. Be sure to have the Radio Code.
Disconnect the cable and clean the cable end and radio connectors with Electronic Contact Cleaner. Re-seat cable then disconnect and repeat cleaning.
Old 09-01-2014, 11:00 PM
Gelandewagen
Ok thanks I will
Where does one find the radio code?
Old 09-02-2014, 04:01 AM
Hashem.M's Avatar
W210 e240
Originally Posted by littlehandegan
Ok thanks I will
The code should be in a credit card shaped ..card in the glove compartment or with the manual...if you cant find it just post a pic of the serial number and model and i'll get the code for you
Old 09-02-2014, 04:08 AM
Hashem.M's Avatar
W210 e240
Wouldn't hurt to check the Radio fuses pins and seats behind the radio itself and fuse 11 or 5(depending on model) in the engine bay and under the rear seat for corrosion, just remove and re insert couple of times.
FYI i did this post using a thread RichardM98 posted :P
Old 09-30-2014, 09:42 PM
Gelandewagen
Just an update. It was a 15 cent fuse!
Old 10-04-2014, 12:46 PM
cudaized's Avatar
No radio code for the COMMAND unit. Only base model radio needs the code. As mentioned, it is typed on a credit card size card that should be in your owners manual package.
Old 10-04-2014, 12:48 PM
cudaized's Avatar
Sweet. All the fixes should be that easy.
Quick Reply: Command Radio out
