Key fob extremely difficult to insert and remove from ignition.
1996 mercedes S500
I have a 2001 E320 that i recently purchased. When i insert the key fob into the ignition, i have to use quite a bit of force to get it in. Once it's in, the key is recognized and there is no issue with turning the key and starting the vehicle. When i go to remove the key, i have to really yank on it to get it out. I also have a valet key that I tried, and it has the same result. Any suggestions would be greatly appreciated.
Sounds like someone forced the key while turning therefore you have something wrong with the ignition module!!----try putting the keys in another MB, remember you will not be able to turn the key however does the key smoothly fit and withdraw from the ignition module!!
1996 mercedes S500
Unfortunately I don't know any one that has another MB that I could try it out on. One theory I have is the mechanism that attaches to the gear selector, causing the ignition to stay locked. You think it's the Ignition module though? Is that a spendy fix? Is this something that I can continue to just deal with the annoyance for a while or does it need to be fixed sooner rather than later? Thanks
MB owners tend to be friendly---surely as you drive around(shopping malls) there has to be another MB or try the local strip clubs!!
I would say it's an annoyance---just be patient placing and removing the key!!
If it turns out to be the ignition module they ain't cheap because you can't use a used one---it has to be new and coded to your vin/key/ecu
