Another lug nut help thread
'99 E320 Wagon
I'm about to purchase this set for the wagon, but the guy didn't have the original bolts with it and I need to order a set.
Spec of my current wheels
7.5x16 ET41
New staggered SL65 set
front 8.5x19" ET 25,
back 10x19" ET 28
They come with a set of Michelin Pilot Sport A/S M+S tires mounted, 255/35ZR19 92Y, and 285/50ZR19 94Y.
I checked the fit, and they actually clear the suspension, brake lines (back is huge, I'll need to roll and full the fender though.
Could anyone point me to the right person/direction to figure out the bolts? The current bolts I have are too long and won't lock the wheel in place.
Much appreciated for taking the time to reply and help.
7.5x16 ET41
back 10x19" ET 28
'99 E320 Wagon
1) look at your existing bolts with your OLD rims. slide the bolt through your
OLD rims (designed for 210). look at the length protruding out the back of the
rim. measure it. the bolt you need needs to protrude out that same amount
from your SL rims. do the math
2) chances are high that the SL bolts are 14mm diameter bolts. which means
you can't just buy standard 12mm diameter bolt. you'll need special, hybrid
bolts with the larger 14 radius ball seat which is on the 14mm bolt.
'99 E320 Wagon
You are absolutely correct my friend. Had the time to do a little research and this is what I have found
not many folks offering the hybrid bolts. i got mine here. shazzam, $65
Former Vendor of MBWorld
RacingBrake offers conversion wheel stud kits for many MB models
Our kits come with ball seat nuts to be compatible with most MB stock rims, Cone seat option is available for users with aftermarket wheels that require a cone seat.
Both M12x1.5 and M14x1.5 Wheel studs are available.
https://mbworld.org/forums/c63-amg-w...ml#post6253738
If you have any questions feel free to ask!
Chris
Chris
