Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- Mercedes-Benz E-Class, C-Class and AMG: How to Remove Splash Shields
Step by step instructions for do-it-yourself repairs
Ball Joint replacement - Issue with rotor splash shield clearance
EDIT: Solved the issue, but figured I would leave the post if anyone else is having the problem. I just bet the splash shield as much as i could which barely gave the the clearance the pull it out, then I bent the shield back. Definitely not ideal, but it worked.
Hey guys,
I'm replacing the lower control arm and ball joint on my '99 E320. I have the lower control arm completely removed, and the ball joint is loose. However, I don't have the clearance to actually remove the ball joint. It is hitting the rotor splash shield.
Below is link to an image showing the problem. It's not my car, just a picture from google but I figured it would be better. There is a bump in the shield right where the mercedes logo is. The bump is what is in my way.
Any advice?
http://www.peachparts.com/shopforum/...l-dsc00340.jpg
Thanks guys,
Jordan
Hey guys,
Any advice?
Thanks guys,
Jordan
'87 190D, '96 E300D (2), '07 ML320 CDI
Take the 2 minutes it takes to remove the shield. The bolt in ball joints are so quick and easy to replace, compared to press-in ones, that you have the time to do it.
On another note, as I'm reassembling everything I'm starting to worry that my steering knuckle is bent and this is why I am having this problem and no one else seems to have it. If anyone has had this clearance issue when removing the ball joint please let me know.
If I remember correctly, it is 3 allen head screws on the outside face.
Remove the wheel
Remove the brake caliper
Remove the rotor
Remove the dust shield
It will take you 1 hour to do the first one, 20 minutes to do the second one.
Remove the wheel
Remove the rotor
I just bend the shield a little bit and put the bottom one in first then lift the arm on top of the joint that connects to the control arm. This job takes about 15 minutes, but i'm also a benz tech with a rack so it's a little different then laying on your back
edit: if the old pin doesn't come out just pull the new pin out and line up the ball joint to the old pin and tighten it so it goes into the pin, replacing the pin or not has no effect on the vehicle as long as there is a pin there.
