vin on m113 engine.
1 Post
WHITE E320 1999, GruppeM Intk, E55 TB, Evosport Pulleys, Longtube Cer. Coat Headers, Cat/res Delete
vin on m113 engine.
Does anyone knows where can i find the vin or part nunber on a m113 engine??? Thanks!
I guess you are saying is that the motor you are looking at has been removed from the chassie and the chassie is not available for inspection---if that is correct---look at the lower block area on a machined surface above the pan!!
PS: Is the engine and transmission ECU with the engine---if so the VIN can be extracted, but that requires special software tools!!
1 Post
Well, im maybe buying an e55. When i test drive it i fell it too slow. The guy tells me that the car havent been used for 8 months so i believe the engine have some little issues. The problem is that the guy is suspicious and i just want to check if it has a 430 block with all the amg things. (Maybe some day he got a blown engine). Im a bit picky and i just want to discard that option.
The VIN should be on the cars registration---if the driver says no comprende---walk away and get a cervasa!!
Then post the VIN and we can check what is under the hood!!
1 Post
The car vin is ok... i want to check the engine vin. Because im afraid he changed the engine.
You have had one to many tacos---there is no engine VIN. There is an engine number and you get the engine number when you check the chassie(car) VIN!!
Last call------post the cars VIN if you want the engine serial number!!!
00 C200 & 00 C55 & 06 SLK55
enrikerace,
Plutoe is correct, there is NO Engine vin, i think you mean Engine # or ID..!,,
if you put your car VIN#, Plutoe can help you then, and everything will be clear to you...
ZAYED,,
ZAYED,,
1 Post
Lets leave hot dogs and tacos a side.
Im sorry if i didnt express myself well.
Yes, what i need is to know where the engine id or # is located in the block. I have the vehicles registration with the Vin and the engine # but i want to check it fisically in the car, because im affraid if this car has a 430 block. I just want to corroborate that.
if you know anyone with access to the Hollander Interchange Manual, that may
help identify the exact/approximate serial number locations on each vehicle.
this manual(s) is used by auto wrecking yards as they part out the car. it is
a great resource for folks wanting to identify which parts are used/shared by
different vehicles (thus the name "Interchange Manual").
possibly the insurance company may be able to help.
you can try this: https://mbworld.org/forums/vindecoder.php
or this: click
or this: click
i have a few books at work so I'll flip through them to see if it clarifies the
location of the stamping.
or this: click
or this: click
