Strange electrical problem involving trunk, power windows and door locks. Need Help!
2001 E220 CDI
Hi, its been a long time since I posted here, usually I find all the solutions by searching older posts but this time I cant find much relating to my problem.
I have a 2001 E220 CDI. For many months I have been having this problem. I have even found a temporary solution for it but now I am looking for something permanent. So the problem is something like this ....
Day 1: Everything is working normal.
Day 2: Everything is still working normal.
Day 3: The trunk stops responding to key fob and console switch but unlocks with the metal key. Everything else is working normal.
Day 4/5: Trunk still not responding and now one of the front power windows switch stops functioning as well.
Day 6/7: Later on locking/unlocking from key fob becomes sluggish.
Day 8: I reset everything by unplugging the negative battery terminal. Few seconds later all is back to normal and life is good again BUT 2 days later same problem starts again.
And then the whole cycle repeats itself on weekly basis ...
What I have tried so far,
1) I have replaced the battery but no luck.
2) I unplugged the electrical wires from PSE vacuum pump, cleaned up the terminals with WD40 (several times). Checked all vacuum pipes. Visually everything seems fine. However, the PSE is just sitting there under the seat, there is no foam packing, no strap, nothing to hold it in position.
What should I do next? Any help in the right direction would be greatly appreciated
I would first test the key fob batteries and obviously replace the low voltage ones--if the batteries are up to voltage----then you have loads of things to be tested to determine the faulty part, however with what is going on in your country, I suspect that you could live with the trunk release problem, because you do not have the diagnostic equipment to isolate the problem----my suggestion check the batteries and if ok, live with the problem!!
2001 E220 CDI
Thank you Plutoe for the reply, I have already checked the key fob batteries and they are fine. We do have the Mercedes diagnostic equipment here, quite a few actually. But I was hoping to fix the issue on my own (if possible) ...
I had a similar problem after my pse got wet from hurricane sandy. Some of the pins on the two pse connectors on the side with lots of wires lots were burned away. The trunk would work a few times after a power reset but then it wouldn't. I also notice my rear interior lights weren't working and my rear doors wouldn't always lock. I lived with it for 2 years but just installed a PSE I bought used on eBay and it all works perfectly now. I spliced in the plugs from the pse I bought
2001 E220 CDI
