Brake upgrade for e430 question
Old 01-06-2015, 07:44 PM
dinoalexander's Avatar
2002 E430 Sport
I am looking to upgrade my braking system for my 2002 e430. I would ultimately like bigger brakes ex. off a w210 e55. I was wondering if the caliper itself would fit with my setup. I have w211 e55 wheels front 18x8 rear 18x9. Or any other suggestions.. I have read c32 brake calipers may fit as well and even work better.
Old 01-06-2015, 09:56 PM
illest's Avatar
4 matic
I had the c32 setup on my car and it will fit with 18's and 17's but might require a small spacer depending on the wheel.
w21 e55 calipers and brakes should bolt right up with no issues. e55 rotors and calipers are going to be more expensive.
c32 setup with 18's
with 17s
Old 01-07-2015, 02:44 AM
Cloudsurfer's Avatar
99 E300
At least you get an opposed piston caliper with the C32 setup!!
Old 01-07-2015, 04:25 AM
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Yeah, you can go with W210 E55 334x32 brakes, they are plug & play..
ZAYED,,
Old 01-07-2015, 11:42 AM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
I got early S55 front brakes, which are the same as the C32 except the spacing is a little different. One of the best upgrades ive done to the car imho. braking power is 2x3 times better and probably 80 percent less dust
see my build thread in my sig for pics.
Old 01-07-2015, 09:42 PM
illest's Avatar
4 matic
c32 brakes look a lot better than e55s as well.
Quick Reply: Brake upgrade for e430 question
