Gas Pedal Stops Reacting
Old 02-10-2015, 12:58 PM
muzunogullari's Avatar
2002 E320 Base
Hello everyone,
This is my first thread on this forum. I own a 2002 W210 E320 Base, and really happy with it overall. Recently though, my car started to suddenly get completely unresponsive to the gas pedal. When I pull to the side, and restart the car, it starts working completely fine again. Even though this happened numerous times, I only got one error code which is 0123 - Throttle Positioning Sensor High Input. I suspect the TPS would cause a sudden shortcut to stop all the connection between the gas pedal and the engine. I feel like it has to be something else, but still unsure. If someone else had the same problem, I would appreciate your help a lot.
Thanks,
Mert
Old 02-10-2015, 05:06 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
You answered your own question---change the TPS and move on!!
Old 02-28-2015, 12:09 PM
rocke320wag's Avatar
2002 Mercedes wagon
I had a similar problem with my 2002 E-320 wagon. Car runs fine but if I aggressively mash the accelerator the car would lug and gradually gain speed. I did the transmission reset and it runs fine now. How can I tell if it is the transmission ECU or the TPS. Thanks
Rock
Old 02-28-2015, 04:20 PM
Plutoe's Avatar
1999 E300TD
Without the tools and knowledge---I would suggest a night course in voodoo to answer that question.
Quick Reply: Gas Pedal Stops Reacting
