Door buzzer
1 Post
1999 MB E430 1998 SL500
Door buzzer
Where is the door chime in a 210? It sounds like it is behind the left vent on the dashboard next to the fuse panel at the driver's end of the dash board. Mine rings 11 times before you put on your seat belt. I am about to go looking for it with my 9mm.
You must have been asleep in physics class.
The audible sounds on you car are manufactured by a piezoelectric quarts loud speaker mounted on the cluster board and no you cant unplug it it's soldered to the board.
However find someone with DAS and he can turn the sound off repeat off not reduce the number of chimes.
