break light stopped working
After about a year of intermittent performance and having to pop the trunk and twist the pink socket holding the brake light it no longer illuminates and gives me a constant error in the dash . is there a diy fix for this or do i just need a new one installed at the mechanic. i have a 1998e320 sedan.
It has been intermittently been going off for over a year and I am usually able to fix it by wiggling the socket around. Now it does not work at all and I have tried new bulb, I also tried sanding down the areas the contacts touch and light doesn't come on at all. Which fuse does the brake light use?
I had this issue with my right rear brake light. I could turn the socket back and forth a few times and it would work for a bit, then off again. Finally, I soldered the surfaces that make contact with the metal brake plate and it's been great since. The socket contacts didn't seem corroded until I tried to add the solder. Had to use flux multiple times to get it to flow.
