W210 Temp and Clock Pixel Display Fix Video
2000 e320 wagon
I created a YouTube video that shows step by step the procedure I used to fix the Temperature and Clock display pixel problem. Here's the link:
2002 Mercedes wagon
I'm having the same problem. Is there any instruction on how to remove the cluster? I would like to have a CD manual of the W20 so I can know this stuff.
Thanks,
Roc
Thanks,
Roc
2000 e320 wagon
The cluster is just held in place by friction. The "tool" is just a coat hanger bent 90 degrees at one end. Slide it between the cluster and the dash, twist and pull on each side, and the cluster will slide out.
