No Power to Radio
2002 E430
No Power to Radio
Hello,
I have a 2002 E-430 with 5,300 original miles. Bought from an elderly couple and everything was working fine until this weekend.
Driving in town I went to change the radio frequency by pushing the scan button. The radio shut off and would not come back on.
I have pulled all the fuses and checked with a voltage ohm meter. All fuses in the fuse box under the back seat are good.
I pulled the radio out of the console and checked the wires and the fuse on the back of the radio, still no power.
Does anyone have the schematic showing which wires are the power wires and what voltage I should be able to read.
Any ideas on what to check?
Thank You in advance for any help.
Brian
Brian
98 Brilliant Silver E320 Wagon
This pinout is correct for my MY1998 but not sure of newer models. As you can see there are two 12v lines on the A connector -- one switched and one not. Hope this helps some.
