220D Starting issues
Old 05-13-2015, 03:33 PM
Tr0nd's Avatar
W210
Hello,
Regular W210 220 Diesel NOT the cdi engine.
I have read the parts on the forum with the most common faults, so I bought a new cps and swapped out the old one today. Now it seems like the car will start when it's hot, so that's good
But, for it to start, I have to put ignition on wait for glow to finish, then ignition quick off and start.
I can not put ignition on, wait for the glow to finish and start, if I do that, the epc will light up and the engine will not go as it should. Then I have to turn it off, I can start it again momentarily and it will be as normal.
Anyone have any ideas what's up with my car?
Old 05-14-2015, 07:51 AM
Tr0nd's Avatar
W210
Also, if I forget to do it that way, just start, I then have to stop it of course, and start it again and the epc is gone and it runs like it should, so now I can drive but then cruise control doesnt work! If I remember to start it 'correctly', the cruise control works.
Old 05-14-2015, 10:01 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
You should really take the time to have the faults read---then you will be in a better position to address the problem!!
Old 05-16-2015, 08:51 AM
Tr0nd's Avatar
W210
Yes, I found some equipment on ebay, but the seller does not reply to my questions, anyone know where I can get the diagnostic gear for a ok price?
Old 05-26-2015, 07:34 AM
Tr0nd's Avatar
W210
P1227 Distributor shaft position sensor Y23/2|2
Is the fault code. Any suggestions?
Old 05-26-2015, 07:48 AM
Plutoe's Avatar
1999 E300TD
Great now you go to WIS/EPC to better define the repair procedure for Y23/212 and define part number----then shop the part!!
Old 05-26-2015, 08:27 AM
Tr0nd's Avatar
W210
Yes, dunno what that is, but the guys that read the code to me said that I have to change the diesel pump. So it's probably too expensive to fix.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
Quick Reply: 220D Starting issues
