E320 starter engagement delay
Old 06-11-2015, 10:34 PM
ljschalm's Avatar
1991 500SL
Folk, I have a new to me 1999 e320 w 113k miles. It has an odd intermittent problem.
In most cases with either key I have hold the key in position 3 for up to 20 seconds before the starter engages. It then starts without an issue. No error codes.
Any experience or ideas would be appreciated!
Thanks!
Les
Old 06-12-2015, 10:02 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Sounds like you have a faulty ignition switch---however the W210 EIS is not apart of the OBD therefore your happy camper reader can't read the module-you will need a factory or equal diagnostic tool to read the switch.
That being said you have checked all the fuses, relays and other modules in the starting circuit!!
Quick Reply: E320 starter engagement delay
