1999 E320 Wagon (Adding a Hitch)
Old 06-23-2015, 08:31 AM
Ynot61's Avatar
1999 E320 Wagon
Research alot found out the "CURT" Hitch is the one for my E320 Wagon and found a Truck Outfitter that will install for just under $500.
My only worry do I need to do anything to my suspension?
I will be towing 700-1000lbs only once in a blue moon. Camping and what not.
Old 06-23-2015, 10:40 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
I wold double check(regardless of weight)with a dealer to make sure you do not need a towing transmission cooler package!!
Old 06-24-2015, 10:42 PM
McBrew's Avatar
1998 E320 4matic wagon
Does that price include trailer wiring? You'll need a powered converter for trailer lights. That'll give you a flat four connector. If you need a 7-way plug, you'll need some more stuff.
I tow a popup camper and an enclosed cargo trailer from time to time. I have the Curt hitch and trailer lighting, plus a 40a power line to the 7-way outlet to charge the camper's battery and run the fridge while I'm towing. My camper's brakes are actuated by a Tekonsha Prodigy Rf wireless brake controller.
Old 06-25-2015, 07:27 AM
Ynot61's Avatar
1999 E320 Wagon
Thanks all and McBrew thank you so much for picks will get price on 4-pin (won't need 7pin) and almost totally forgot about the extended ball configuration which I will totally use!
Old 06-25-2015, 08:48 AM
renault12ts's Avatar
W215 CL500 2005
Non US cars are allowed to tow far higher weights and do not need suspension work...and if only towing up to 1000 lbs...will not need transmission coolers either.
Quick Reply: 1999 E320 Wagon (Adding a Hitch)
