Sunroof sloping down in the back.
Old 07-05-2015, 04:12 PM
Dnasty's Avatar
2010 e550 coupe
I recently changed the sunroof seal on my w210 e320 and now when i try to close it the back part (closest to the passenger) slopes down and it seems to only become even when I expand it (the position that normally tilts upward). I have no idea what could have caused this all I did was change the seal... I have even tried with the seal not in the sunroof and the same thing happens so I know that is not the issue.
Old 07-06-2015, 08:48 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
You, did not do the install job correctly---it's a doooooooooooooooooo over---do a search and read the install directions!!
Old 07-06-2015, 09:02 AM
illest's Avatar
4 matic
Look at the information in this thread there are screws on the side you can use to adjust the slope.
Old 07-06-2015, 05:54 PM
Dnasty's Avatar
2010 e550 coupe
Ah this must be it I loosened some side screws in hopes it would make it easier to slip the seal in did not know they had to do with the slope. Guess I need to go back and try to screw them exactly how they were before.Thanks for the info.
Quick Reply: Sunroof sloping down in the back.
