[HELP]W210 E290 1996 Ecu wiring diagram
Mercedes E290 1996
hello,
i experience problem with my E290 ERG or MAF systems. i'd like to know where they are wired on the ECU to check which one doesn't operate properly.
Is there someone here who can post the ECU diagram of this specific model here?
Thanks in advance.
Thanks in advance.
What you are embarking on is very difficult without the proper tools and wiring diagrams---never the less you need to gain access to MB WIS docs 07.1-195= testing exhaust gas recirculation; 07.1-150= 602.982 vacuum diagram and DFI wiring diagram PE07.13-P-2000.99b
The MAF pins are(pin 1) to 21 and(pin 5) to 28; The EGR\ARF pressure control flap vacuum transducer(pin1) to pin 35---I have assumed that you know the MB wiring colors for both systems!!------A la prochaine!!
Last edited by Plutoe; 08-13-2015 at 02:57 PM. Reason: added more specific MAF\EGR pin info
Mercedes E290 1996
