Spring and suspension for E320
Good day,,
I was installed Eibcach spring coil on my car
but after around 6 months with daily use on highway i found that its damaged my suspension
so i decide to change it and reinstall to old spring coils
the problem after installing the old spring and new suspension
car getting to high from both side rear and front
i return to the deal to check the suspension if it there is something wrong but nothing
but he mention that we might change the spring coil and it become lower.
spar part have 3 time of spring the different is just with the thickness.
So my question if i bought the lowest thickness is right that car will be lowered/
waiting for your participation.
there isnt enough details to conclude anything because your description is too general
and lacks critical details like measurements, the specifics of the damage, etc. thickness
alone is not sufficient to gauge spring tension, however spring rate would be key.
The problem that after i install the new suspension and the old spring
car getting to high in the front and rear.
which mean the distance between tire and Fender.
So i'm thinking to buy new orginal spring from spar part that different from what i install.
but i found that all of them has the same length the different is thickness.
its almost looks like this picture.
