Loud bangin noise E430
Hey guys just wondering what this could be, when i accelerate slightly hard i get it like once maybe 2. When hard accelerating i i get it 3-4-5 times just depends, it sounds like the car is struggling to get traction. But it takes off very fast with no hesitation 0-62mph clocked at 6.2 seconds! So this bang noise does not slow the acceleration down. I have disconnected esp by fuse noise still there. There is no weird strange sounds when driving, transmission shifts good and no howling sound from diff.
When i do burnout while standing on the brakes the bang noise does not come neither when standing on brake and giving it gas but not enough to brake the tires loose,
I have checked the driveshaft also the axles.
So far i know i have bad outer wheel bearing in the drivers side back tire.
I do not do burnout my friend just told me to do it to see if the bang appears
Just a thought, but did you ever think of replacing the air in one or more of the rear tires with water---I read that suggestion on a Syrian fishing forum and it seemed to work in this guys case, however his problem was when he did what you did, but in reverse!!
Hhah what the f***
I had random loud bang noise when I had a broken front spring. Mostly around turns, sometimes under acceleration or braking. The broken section was getting caught on the rest of the spring and snapping loose under certain conditions...
