replaced shift rod bushings, shift rod still rubbing on driveline coupling
Old 10-01-2015, 10:00 PM
MTBcrazy's Avatar
2000 e320 4matic wagon
I just replaced my shift rod bushings a couple of months ago and it fixed the problem until today. The shifter is vibrating violently at times, especially around corners, hitting a bump in the road or starting from a light. I have not looked under the car yet but I can't believe there worn already.
The car is also vibrating a little more than normal when at a light, does anybody think it could be motor mounts or tranny mount? I was just under the car flushing the radiator,changing hoses,thermostats and fresh coolant. I glanced around with a light. I didn't notice any fluid leaking from motor mounts. I didn't look at the shift rod because I thought that problem was solved.
Thanks in advance for any suggestions.
Old 10-02-2015, 11:01 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Sounds like mounts to me---simple test put the car on a lift have your counterpart play with the accelerator while you are under looking at the drive train---wada you see??
Old 10-02-2015, 05:06 PM
MTBcrazy's Avatar
Thanks Plutoe, that's kind of what I was thinking it might be. Going to try to get under it tomorrow. The car was involved in an accident before I bought it. Not sure the prior owner replaced the mounts-judging from the work I saw done on it. Thinking about replacing the transmission mount as well. Do you concur?
Old 10-03-2015, 07:12 AM
Plutoe's Avatar
1999 E300TD
absolutely!
Old 08-13-2017, 07:40 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
Last edited by GatorMB; 08-13-2017 at 08:13 PM. Reason: response landed elsewhere deleted
Old 09-04-2017, 10:55 PM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
oops - deleted
Old 10-20-2017, 09:16 PM
xclream's Avatar
R350
Got mine swapped. For those who don't have clocks that are considering, this is a GLC part, goes straight on without any problems.
Quick Reply: replaced shift rod bushings, shift rod still rubbing on driveline coupling
