E300D Fuel Leak(s) parts list
My OM606.912 has some fuel leaking onto and around Fuel Filter Mount. Couple other areas look damp also. Hard to tell what exactly needs to be done. Have cross over Intake Manifold design. Which covers most of what I need to inspect!
My question to all you is this. Has anyone made up shopping list for all lines, brackets and seals that should be replaced when I go in?
Want to do best job I can on this project. Thanks in advance
There are loads of good\bad lists on this an other lesser forums--however the correct way to address the problem is to get a FREE subscription to MB EPC--put your VIN in and search all the individual parts for your specific engine---very simple---not only do you see the complete layout with part numbers for your VIN, in the process, you also learn much about your car !!
Received 1,730 Likes
1922 Ford Model T / no OBD
Go to benzworld and you will find parts numbers, drawings and pictures served in stickies on sliver plate.
Great suggestion if your looking for a date, but like the posted indicated in post 4 he made the correct move and subscribed to MB EPC---we don't need the spam!!
So you spammed him into EPC but will not let him to look at pictorial and wealth of experience from fellow car owners.
Some advice Plutoe
Some advice Plutoe
No need to struggle alone.
As I said, you have the whole procedure detailed on other side.
I don't think this forum will allow linking to the competition, but you can always PM me.
Since you mentioned the leak as "onto the fuel filter mount", I suggest that you find the return line that comes out of the filter mount right behind the primary filter. The o-ring on the plastic T fitting where it fits into the filter mount can be neglected and has a tendency to leak. The fan blows leaking fuel around so much it can be difficult to tell where it is coming from. I suggest that you wrap a strip of paper towel around suspect joints and run the engine a bit to see if the fuel saturates the towel. In my experience with this engine, once you solve all the leaking problems, celebrate quickly, because you will soon be looking for the source of another leak.
Here is my list. Should keep me busy for a couple minutes!
Damage code Item no. Part no. ES1 ES2 Designation/description Quantity
119 A 606 070 05 32 LINE
(RETURN LINE) FROM INJECTION PUMP TO FUEL FILTER 001
95 A 605 070 15 32 LINE
FROM FUEL FILTER TO SHUT-OFF VALVE 001
83 A 606 070 04 32 LINE
FROM FEED PUMP TO FUEL FILTER 001
74 A 605 070 08 32 LINE
FROM FEED PUMP TO SHUT-OFF VALVE 001
56 A 605 070 07 32 LINE
FROM PREFILTER TO SHUT-OFF VALVE 001
146 A 615 476 03 26 HOSE
FROM NO.1 NOZZLE HOLDER TO FUEL RETURN LINE
340 MM 001
29 A 601 997 01 48 SEAL RING PREFILTER 001
14 A 009 997 92 48 SEAL RING 001
11 A 009 997 81 48 SEAL RING 001
126 A 017 997 22 48 SEAL RING
FUEL LINE AND OVERFLOW VALVE ON INJECTION PUMP 001
128 N 007603 012102 SEAL RING
FUEL LINE AND OVERFLOW VALVE ON INJECTION PUMP 12X16-CU 002
32 A 605 070 14 32 LINE
FROM THERMOSTAT TO PREFILTER 001
71 A 604 997 00 45 SEAL RING 002
44 A 606 997 06 45 SEAL RING
INTAKE LINE TO INTAKE MANIFOLD 004
340 MM 001
