blinkers, hazards, wipers, horn and washer fluid quite working
1999 e320
mid turn today the turn signals quite working, upon further investigation the signals, hazards, horn, wipers, and washer fluid all quite working as well. seems to be to much for a simple fuse.... any ideas on were to look for the problem?
You can start to look in the drivers side fuse\relay box(under hood)however they are independent systems running via the front SAM and I doubt that a single fuse or a relay will cause all that comotion sounds more like a bad SAM.
PS. If you dident know what epc ment, I seriously doubt any of this will make any sense---see a pro!!
