help nothing works
help nothing works
I recently went to a locksmith instead of the dealer to fix a fob problem on my 2000 E-320. Well when I got the car back it started right up but nothing else that is connected to the ECM does. on top of that the radiator fan stays on at full speed from the time I start the car until l i shut it off. any help you give me is appreciated. thanks
This is another case of trying to do something on the cheap and winding up winding up in a POS. Take the fob back to your expert and get on with your life!!
PS: The fob issue has nothing to do with the fan staying on---the fan issue is faults in either two areas---A-engine coolant temp sensor or B-AC refrigerant temp sensor
