E300TD 1998 Engine noisy when temp below 5C, fine when warmed up...
<table id="post6683665" class="tborder" align="center" border="0" cellpadding="4" cellspacing="0" width="100%"><tbody><tr valign="top"><td class="alt1" id="td_post_6683665" style="border-right: 1px solid #000000">Had the car 5 yrs, 98k on the clock and drives very smoothly.
However, after starting, it hates the cold and is very noisy when the temperature is below 5 degrees c, or about 50F until the engine temp reaches normal..
Also, if I put the "ultra" BP deisel fuel in, the engine runs more quietly both hot and cold.
I would imagine that I could quieten the engine by adjusting / replacing something - but is it a garage or a diy task?
</td></tr><tr><td class="alt2" style="border: 1px solid #000000; border-top: 0px">
</td> <td class="alt1" style="border: 1px solid #000000; border-left: 0px; border-top: 0px" align="right"> </td></tr></tbody></table>
Does the car still have the three sound deadening panels secured to the under car--next time on a lift look under the rad, crankcase and transmission!!
And remember you have a mechanical fuel pump and injectors----noisy at low rpm's
What viscosity of oil do you use!!
Received 1,729 Likes
1922 Ford Model T / no OBD
Check for air bubbles in fuel tubings.
If tubings are over 10 years old- replace them
Other thing to check would be chain tensioner. They are oil-charged and cold oil is taking longer to fill them up.
No idea what oil is in there, probably 20/50 Castrol. As to the mechanical pump and injectors being noisy, when the engine is warm, it is pretty quiet for a diesel.. but I do understand that by then, the metal parts have expanded with the heat...
I'll look for those 3 panels you mention thanks Plutoe.
Air bubbles in fuel tubings... replace as required - OK thats one for the local garage! As is the chain tensioner...
I'm not a mechanic so again, off to the garage for that option, but I really like the logic of the cold oil taking longer to fill them up...
Really appreciate the ideas, even though the car is old, its a great drive and with it being so well behaved when its warm I want to "look after it" if there are early signs of trouble like the extra noise when its under "normal" temperature.
I'll look for those 3 panels you mention, and maybe I sould use a different oil, 10/40?
thanks Plutoe.
thanks Plutoe.
I can do that. As to why I said "probably", thats what I thought my local garage used.
When I last changed the oil, thats what I put in a car.
I'll ask to be certain...
Now I am feeling old and a little out of touch!
Appreciate the feedback..
