w210 front central jack point
Hi - can anyone give me the part number for the front centre (under front chassis crossmember) jack point - I think it is a rectangular plastic block which plugs into a hole in the crossmember - it is missing on my 1998 saloon. Thanks, Ian.
Received 1,730 Likes
1922 Ford Model T / no OBD
Plug A2039970186, or 2039970186, or 203 997 01 86
To make proper determination you need to mach the part to your VIN (as always)
Have confirmed the part number is A 002 997 32 86. It is listed on the Mercedes EPC under "Body Shell" - "Expansion Plugs, Grommets" and described as "PLUG - Jack Take-up Device On Frame-Type Integral Support 25x7.5mm"
