Help! Multi-function Steering Controls
Just had inspection & no probs then put Liberty Mutual "Right Track Device" Into OBDII port & immediately all different electrical issues now on my plate! Unable to access/use multi-function steering controls, have had to replace back break light & sometimes it works & sometimes it doesn't, ABS & BAS light will come on then when shut car off & restart it's not on anymore, my stereo will just shut off randomly, my AC won't get cold now & just had it serviced!! This car was in excellent condition & no problems, makes me sick!!!!!! Thanks a lot Liberty Mutual & Right Track
YOU HAVEN'T HEARD THE LAST OF ME & I'M NOT LETTING YOU JUST GET AWAY WITH THIS. No wonder our Country is in the condition it's in.
Welcome Mr.Mcduff--your best bet is find someone with good diagnostic equipment and with the correct equipment hopefully he will be able to correct the issues--other than that check your tire pressure,ashtray,glovebox,trunk,wash your rims,check your canister shutoff valve and remove all bugs from the grill!!
Received 1,730 Likes
1922 Ford Model T / no OBD
Disconnecting the battery for few minutes is worth the try.
Make sure you know how to reset radio, windows and steering.
