Turn signal issue
Turn signal issue
My 2002 E55 is having issue with the turn signal lately. When I pressed the stalk to make a left turn, the right signal/light flash instead, and the only time I get left turn signal light is when I slightly push on it but becomes right signal flash when I push all the way down. This issue happens sometime and other time everything is normal. Any suggestion or diagnosis with this? TIA.
John
John
Dear John---sound familiar---you just did the diagnostics-----you need a new combi switch, however some of the older misinformed spammers from BW will advise--- Oh hell yea just remove everything and get a soldering iron out an fix the switch--wada bonehead!!
