Heater/Aircon problem
1 Post
1995 Mercedes E320 sedan
Hi...recently the heater/aircon unit has stopped putting out air, everything seems to work on the dash heater console and the fan kicks in for the heater but nothing comes out...what is the possible fault here?
Received 1,730 Likes
1922 Ford Model T / no OBD
If you have climatronic - read the codes, then clear them and do 1 to 8 sensor readout in 3 situations:
1 in the morning before engine start
2 in the hot afternoon engine off
3. few minutes after #2 with engine on.
Without climatronic you can use SD to read the sensors, or start with measuring refrigerant pressure with traditional gauges.
