E430 exhaust query (trolls need not reply)
Old 08-04-2016, 02:19 AM
R_Bzdel_E430's Avatar
2002 E430 4matic (W210)
I did some exhaust work a couple months ago on my E430, deleting the resonator.
I didn't have immediate access to the correct pipe pieces to re connect the two halfs, so I was driving around for a bit with just the catalytic converters (4) and dumping out the sides. It sounded awesome. EXTREMELY loud at WOT under load, but a very nice grumble at idle and not bad at all on the highway.
When I finally did have what I needed to re assemble the system
properly, with the resonator deleted, I was less than impressed with the result.
My question is if I delete the converters, with the O2 sensors upstream, will this cause the MIL lamp to come on?
There are no enforced emissions regulations in my province.
Old 08-04-2016, 08:46 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Yes, but simply remove the bulb and no MIL.
Old 08-04-2016, 11:29 AM
PDX4matic's Avatar
1999 e320 4matic
So by saying you were less than impressed with hooking up the rest of the system, are you talking sound or performance?
If sound, you could just get a different muffler setup to open it back up downstream (eliminate the 1st muffler and replace the last muffler with a straight through type) so you still have emissions properly gauging your air fuel ratio AND you can have that nice MIL light still turn on when a major issue arises?
Old 08-04-2016, 01:56 PM
Clearly you didn't read the entire subject field.
Old 08-04-2016, 03:24 PM
Sound. I wouldn't expect much gain in power unless I had some BRABUS headers, 3" pipes and a tune.
Old 08-05-2016, 02:13 AM
fabbrisd1's Avatar
Received 1,099 Likes on 805 Posts
A gaggle of MB's
Yes you will have CEL, and frankly poorer performance... you can choose to add a O2 sensor "eliminator" but you will still have poorer performance..
Old 08-05-2016, 01:09 PM
illest's Avatar
4 matic
get some high flow cats.
Old 08-05-2016, 03:14 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
My 320 has O2 sensors upstream of the two cats. I removed the cats 6 years ago and still no CEL.
Old 08-06-2016, 01:29 PM
kajtek1's Avatar
Received 1,730 Likes on 1,380 Posts
1922 Ford Model T / no OBD
The 1996 I6 engine is different than V6 and V8 engines of next generation.
The V6 and V8 are having 4 of O2 sensors.
Not having smog test, I think high flow cats are your best option.
Bare in mind that smog requirements are coming to more and more jurisdictions and your province might do it in next few years.
California made smog for diesels about 6 years ago and grandfathered it back to 1998 models.
That made owners of modified diesel pickups pretty scare.
Old 08-08-2016, 06:16 PM
I lucked out then
Quick Reply: E430 exhaust query (trolls need not reply)
