Replacing caliper(will it fit)
Old 08-07-2016, 12:42 PM
Benzdriver12's Avatar
2001 E320
My brakes and rotor were very worn only on the rear driverside. Was told that it was caused by the caliper. The fastest way for me to get a new one is to get it from my local import junkyard. They only have a 1996 caliper in stock and I was wondering if it would still fit on my 2001.
Old 08-08-2016, 03:49 PM
Plutoe's Avatar
Received 1,052 Likes on 973 Posts
1999 E300TD
Why replace with junk. You can get a rebuilt one from NAPA and get on with your life,however if you gotta know then post your VIN!!
Old 08-08-2016, 05:00 PM
2001 E320
Found one for the same year, just need a quick fix so I can get to a funeral in 2 days. All of the auto parts stores I called won't be able to get me one for 4-5 days.
Old 08-08-2016, 06:14 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
To the best of my knowledge they are the same. For sure the brake rotor dimensions are so i assume the calipers are. If the spacing is a little bit off, a good temporary fix is longer bolts and a couple washers.
Old 08-08-2016, 06:51 PM
2001 E320
I ended up finding one from a car the same year as mine with not to many miles on it.
Quick Reply: Replacing caliper(will it fit)
