A2 connector on the fusebox? (Switching engine m112)
Old 09-10-2016, 04:42 PM
S610's Avatar
Mercedes E320T -99
Hi everyone!
Im changing the engine (M112.941) in my E320 -1999.
When i looking at the cable harness going from to the engine to the fusebox under the hood i have a connector with two cables going to the slot named "A2". But i dont know whats it is for. i dont have that connector on the harness on the "new" engine im putting in.
So if someone have anything to tell me about it ill be glad! Here are some pictures.
Old 09-10-2016, 10:30 PM
raymond g-'s Avatar
99 E320
gets tricky as MB identifies fuse blocks by labels and i think you're referring to F fuse block. but even so, there are sub categories labeled A, B, C, D. I'm not very familiar with the interface so am pulling my hair. This is much more detailed and involved vs Motor and Chilton manuals I grew up with.
Would be nice if you could provide me with part number and I'll see if that helps. Also wire color codes as well as adjacent fuse labels so I can be sure I'm close. The zoomed in photos looks just like all the others and I can't identify where I am with your photos.
VIN might help, too
Old 09-13-2016, 11:34 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Originally Posted by S610
Hi everyone!
Many things are so called tricky when you speculate--post the host VIN and we will look at the front SAM for the correct answer!
Quick Reply: A2 connector on the fusebox? (Switching engine m112)
