96 W210 shaking / etc acceleration
A suspect could be wires, plugs and coils--when was the last time changed. Another suspect could be throttle body---any faults. Another suspect could be loads of things---get the car scanned!
PS: have you shown a reputable mechanic your vids!!
if it does it cold like mine the rpm needle bounce,its a servo in the trans.I would not worry.
1997 Mercedes E420
Hi Guys, I Also have a similar issue were it jerks a little bit i Notticed it happend when it was cold today. but goes away after car Warms up
( OLDSINNER111 ) I Notticed you said it could be a Servo you think it will be ok?????
Also is the ASR suppost to Slow the Car down on its own ???
I Have a Check Engine Electronics and a ASR Light Also Had a Mech/ Pull Codes P0173
Please Help??
1997 Mercedes E420
Please Help??
1997 Mercedes E420
Please Help??
1997 Mercedes E420
Please Help??
1997 Mercedes E420
PS: When he pulled the fault how did his scanner describe the fault or did he just lick his finger and point it to the wind??
