Mercedes E290TD W210 - dash stays on
Mercedes W210 290TD
Just joined this forum, hopefully someone here can help.
When I turn the key off the dash stays on, its also flashing rapidly so this seems really weird to mee. The problem is before the fuse I guess, since the dash turns off with the fuse taken out.
Then I have the ABS light on, ideas on that? Also ASR + BAS lights are on, the car drives fine but these are the problems I have.
well ok, the heat control doesn't seem to be working either, now and then it changes temperature when Im spinning the heat control..
W210s seem to have the weirdest electrical gremlins... worse than my Lada
Regarding the cluster staying on----you have issues with your front SAM
Regarding the ABS,ASR and BAS lights that could be loads of things(wheel speed sensors to control modules) to guess at---don't guess get the car scanned and you will learn the issues, then you fix the issues!!
Mercedes W210 290TD
