Diesel pump sinchronyzation process MB E300 TD 1998
Mercedes E350 2006
Hi, to be honest I'm not a diesel guy, but some friend of mine bring to my shop a 1998 Mecedes Benz E300 turbo diesel with the diesel injection pump out, I'm trying to synchronize the pump with the engine with the apropiate tool, but I thing that I'm doing something wrong, can some body let me know what is the procedure step by step, I have a WIS/ASRA and found some info but is kind of confuse, any help will be appreciated, thx
Post the VIN------------------additionally, you say you don't understand the pump removal process outlined in WIS------if that is the case why did you fool the customer into thinking that you could do the job---now you are screwed as the WIS documents outline very simply the process and the special tools you need to preform the task-----it's guy's like you that give a bad name to the repair of MB cars!!
Mercedes E350 2006
Respectfully Mr Plutoe, I invite you to read again my question before you said all of that, I SAID CLEARLY I'M NOT A DIESEL GUY & IS A FRIEND OF MINE IS NOT A CUSTOMER I"M NOT WORKING ON DIESEL ENGINES, I just asking for help not for some body that does not read the post and blame me for nothing, your comment is not appreciated at all specially if you are not able to help!!
Received 1,730 Likes
1922 Ford Model T / no OBD
When you scroll Plutoe's replies, about 50 % of them are "post your VIN"
This is what he does here.
You will find diesel manuals here http://www.w124-zone.com/downloads/M...W124/Main.html
When I was doing IP synchronization, I substituted the timing tool with a piece of 3/8" copper tubing.
I hope the engine has a basket installed for IP removal, otherwise it will be DS.
606 engines have the same IP timing what 603, so don't hesitate to check both WIS.
mocagiuseppe (10-14-2016)
Mercedes E350 2006
Hi Mr kajtek1, I would like to said thank you, there are a very nice and clear explanations, now I will be able to set-up the pump correctly at this time, I really appreciate so much!!
