BAS, ESP, etc
BAS, ESP, etc
About 2 years ago when I bought my E320 I had to replace the Brake Light Switch because of the dashboard lighting up. This was not a random thing. However now I am getting random and sporadic versions. They don't light up every time I drive and they always go out if I turn the car off and back on.
Has anyone experienced this or have an idea? Am I going to have to replace the BLS every 2 years?
Also, not sure if related, my radio (factory) will no longer come on when I start the car. I have to press the button to turn it on or off. On top of that, every so often it will no work at all. After a few times of driving it it will work again.
To me - 1st thing to do is pull/clean battery cables/perminal including the ground. Always have KEY OUT during battery disconnect/reconnect. When battery disconnected - good time to pull/clean/brush all fuses. Battery out take for auto parts store load test. After fuses and cleaning cleaning - after reconnect - radio code needed - reset steering angle sensor - reset aux systems - follow your owner's manual for procedures - or download owners manual for W210 from mbusa web site in Owners Section.
ALWAYS clean connections/fuses - and load test battery BEFORE any voltage/charging analysis using Climate Control Read Out.
There are a LOT of glitchy gremlins come up - when (a) battery connections and/or ground corroded/old (b) fuses corroding (c) battery is starting to fail and/or (d) or a non-MB/knockoff brake light switch starts failing easily within 2 years for sure.
Cover this small stuff 1st BEFORE you let Blutoe get in your head..
The following 2 users liked this post by fabbrisd1:
R2dMax (11-01-2016),
shadenfroh (11-03-2016)
Received 1,730 Likes
1922 Ford Model T / no OBD
That sounds like voltage problem to me too.
How old are alternator brushes?
R2dMax (11-01-2016)
yet . The way things have gone for me with this car, I'm sure its bad, going bad. Never hesitates to start though. But I see how the affected systems could be voltage related. Should I have the alternator tested then?
Short brushes can act for pretty long time before they die permanently.
But if you have over 150k miles or drive with lights on a lot at lower mileage - you will need new brushes sooner than later.
You can also drive with car voltage on display to confirm what the real issue is.
Sensor #24 on climatronic.
