'98 e320 Rattling Noise at Start Up (Water Pump?)
Old 11-29-2016, 11:42 AM
paige320's Avatar
1998 E320 4matic Wagon
Hello!
My 1998 e320 wagon makes a pretty loud rattling sound for a few minutes after start up. I don't really notice it while driving. Upon looking under the hood, the sound is coming from a fan hitting against an enclosure. The fan is hitting because of the pulley its attached to being loose, like the bearings are loose. There is a leak below this area, and it leaks out the bottom of my car. Also, I got a "Coolant level" message yesterday, and had to refill the coolant. I have heard that running low on coolant is another sign of a water pump problem.
Does this sound like a water pump problem?
Thank you!
Old 11-29-2016, 01:34 PM
fabbrisd1's Avatar
Received 1,098 Likes on 805 Posts
A gaggle of MB's
Yes - weepage/seeping at the bottom hold of the water pump - plus what you describe as symptom indicate a failing water pump.
Your yr has two types of pump - "2-outlet" or "3-outlet" - either Graf brand/manuf or Laso n=brand/manuf are good OE equivalent replacements - make sure you get correct # "outlets" on the replacement pump. China brand or retail store brand water pump not recommended.
Depending on your ownership intenetion - water pump replacement is good time to check for belt and/or belt tensioner replacement as well - Continental brand sells a "kit" with both belt and replacement belt tensioner as a set - with correct INA original tensioner. Again - China brand or store brand are not good.
paige320 (11-29-2016)
Quick Reply: '98 e320 Rattling Noise at Start Up (Water Pump?)
