2000 E320 high beam not working after replacement
I just replaced my headlight assemblies with DEPOs due to many problems with hazy lights and bad wiring. I noticed that the passenger high beam light is not working, which was a problem before the replacement but I figured it was the wiring's fault. The new DEPOs came with wiring and bulbs, so I figured all of the problems would be fixed. Could the light not working be a problem with the new wiring? Or the electricity source? I've tried multiple bulbs and none work in the right side high beam, but don't see any apparent problems.
Check your fuses mate, i'm pretty sure the hi-beams has separated fuse left/right. drivers side dash fusebox has all the light's fuse's. Normaly if you have a bad wires inside the old headlights they will blown the fuse
Fabio Daniel
Fabio Daniel
I don't think you could've been more right. Took it to my guy today and he said a fuse had blown and it was separate for the high-beams. Most likely blew when the old wires were smoking.
