E-Class (W211) 2003-2009
Service Brake "Visit Workshop!"
Rating: Thread Rating: 6 votes, 5.00 average.
Old 06-09-2006, 04:36 PM
Tariq's Avatar
S500 W223 2021
Old 06-09-2006, 08:50 PM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
Tariq,
I'm at a loss for ideas. I would probably change the stop lamp switch as was suggested earlier and watch the car for a couple of weeks. If the warning still appeared, I would check all three pad sensor's connectors to make sure they're not loose. If you can find it, WIS document AH42.10-P-0003-01A has info pertaining to the pad sensors.
Regards,
paul....
Old 06-10-2006, 01:10 AM
LeslieRushforth's Avatar
E320 CDI W211
Yes I took my car to the dealers four times about the problem (BRAKES VISIT WORKSHOP).
The malfunction would not retain the information on the problem....this would reset after 15 minutes when the car was switched off.
The dealer fited new censors,wiring loom and removed the ((50% brake wear censor which by the way should be done on recalls because this can cause interference on the radio when the rotor cuts the 50% censor)).
FINALY on the fourth visit I drove to the workshop with warning BRAKES VISIT WORKSHOP still visuable on the malfunction display.....the technician pluged the workshop computer (STAR DIAGNOSE) printed out the report and showed me that it was a faulty brake light switch.
Took just over 30 minutes and I was driving the car back home.
Problem solved......no more malfunction 3 months later plus 2000 miles.
Old 06-10-2006, 04:10 PM
paulv's Avatar
Leslie,
It's good hearing from you again. By the way, I replaced my rear pads/rotors last week with confidence because of the info you furnished me some time ago with dealing with the SBC -- thanks!
regards,
Paul....
Old 06-15-2006, 04:34 AM
Tariq's Avatar
S500 W223 2021
I did the DAS setup for the 2nd time.. it removed, but it comes back agine..
i will try the brake light switch sensor...
Any one have idea about the part number and how it looks in photo?
Is it hard to do self installation?
Regards....
Old 06-15-2006, 07:13 AM
Tariq's Avatar
S500 W223 2021
I opened the cover which is under the dashbord where the padels... i notice the following as u can see the the photos... i guess this is the sensor or switch which i must replace.. i hope someone can explein more..
btw i notice a cable which is unpluged too, i try to find where it must plugged but didnt find...
any one can advise?
Regards
Attached Thumbnails Service Brake "Visit Workshop!"-dsc01295.jpg   Service Brake "Visit Workshop!"-dsc01296.jpg   Service Brake "Visit Workshop!"-dsc01297.jpg
Old 06-17-2006, 01:25 PM
  #32
D_TECH's Avatar
there is a tab you need to squeeze on the sensor you have pictured and then you turn it approximately 90 degrees and it'll come out. dont forget when you install the sensor you need to make sure the tan/white tab that gets compressed is fully extended (you can press it dont and hear the notches when its going down, but make sure its fully extended). The stop lamp switch should fix that cluster message 99 percent of the time.
Old 06-17-2006, 04:17 PM
  #33
Tariq's Avatar
S500 W223 2021
Thanks D_TECH...
I feel well after i red your comments...
btw do you have the part number for that switch?
and about removing it, do you mean i must turn it to the right will 90 Degree then pull it out ...?
Hope to get more explien rather than i may broke it ....
Old 06-18-2006, 08:35 PM
  #34
D_TECH's Avatar
i dont think I have any switches at work to get the part number, sorry, and yes you squeeze the tab and turn to the right.
Old 06-24-2006, 04:56 PM
  #35
Tariq's Avatar
S500 W223 2021
I got new switch and replace it, but still showing "Service Brake" Visit workshop!!!
Old 06-27-2006, 07:52 AM
  #36
Tariq's Avatar
S500 W223 2021
Old 06-27-2006, 08:14 AM
  #37
Jakpro1's Avatar
2003 E55 & 2014 GL550
This gonna sound a little dumb but you sound like you are kinda at the end of your rope. Very similiar thing happened to me with the light. I called the service guy and he shot this out instantly, "You bumped the emergency brake with your foot. Sometims when getting in the car, your left foot brushes that emergency brake and she sets off the sensors." Told me to make sure emergency brake was ALL the way up and drive for a few mins. WHAMMO....light GONE. Sure hope this works....you have been through a lot. Good Luck.
Pepe1969 (12-09-2020)
Old 06-27-2006, 11:24 AM
  #38
Tariq's Avatar
S500 W223 2021
After i replace the Sensor, i drove the car and pushed the brake , i made a trip and keep pushing, but the warning still appear!...
Old 06-27-2006, 04:28 PM
  #39
byttcool99's Avatar
E240 03
Hi Tarek
Try to remove the wires that connect the brake pads to the disc. they are small wires that u bought for 10 AED.
When I changed my brake pads and turned on the car, I received that message with beeping sound, then I removed those wires and it is all gone.
Take the car to Dubai even if it is imported they will fix it for you because this is a recall and they had to change it. I tool mine to Sharjah they refused to fix it, then I wrote a complaint message and sent it to the GM of Dubai CCing their Customer Relations. It was unbeleivable the service manager called me (he is German) and appologised and told me to get him the car.
They fixed many things for free and did all the recalls, the whole job was worth around 15,000 AED (more than 4000 US Dollars). they changed the brake bump for 10000 (around 2500 UD dollars).
Old 06-28-2006, 11:15 PM
  #40
Tariq's Avatar
S500 W223 2021
Well thanks for your comments, actully i replaced the wiers after i got that msgs and connect the DAS to remove that message so it gone, but after awhile it comes back agine once i turn and stich on the ignation!.
Old 06-29-2006, 04:46 PM
  #41
konigstiger's Avatar
Received 4,414 Likes on 3,144 Posts
'71 Pinto
Between maintenance checks it is a good practice to apply the PB once or twice while driving at approximately 30 mph. Apply lightly until a slight drag is felt. Keep applying the brake for about 10 seconds while pulling the release lever out before releasing the PB completely. You said you already did this however, while doing so did the PB fail to release completely, and/or was difficult to operate?
Inspect the PB cable for evidence of chafing in the area of the fuel tank retaining strap (both sides of drive shaft). Vibrations due to driving create a relative motion between the PB cable and the fuel tank retaining strap. In extreme cases, the sheathing of the cable may become chafed allowing water to enter the cable assembly which may lead to corrosion of the cable.
Old 06-29-2006, 05:08 PM
  #42
byttcool99's Avatar
E240 03
Just remove them
Just remove the wires, don't replace them
Old 06-29-2006, 05:19 PM
  #43
'71 Pinto
Absolutely! …Didn’t think I had to mention “replace if necessary”:
Edge Guard A001 987 76 25
PB Cable (left) A211 420 02 85
PB Cable (right) A211 420 03 85
Old 07-04-2006, 07:38 AM
  #44
Tariq's Avatar
S500 W223 2021
Guys,
I toke my car to the workshop, they informed me that, the problem mainly comes from the SBC !,,, yes correct that about 3 workshop said the same after connect the car with DAS.
The workshop is going to change that part under waranty, I wonder what make my SBC like this, i hope someone can tell the reason in order to aware from braking any more...
Old 07-06-2006, 04:37 PM
  #45
Tariq's Avatar
S500 W223 2021
Finally, its over, i picked my car today with new SBC system, i notice big diffrent in braking than before, its smooth and no need to push the padle more,, generally its amazing than the old version 2003 models... after modified.
but once i take out my car, i turn on the audio it shows me only Mercedes benz logo , then it turn off , the workshop closed agine.. hope someone can advise what is the problem agine...
attached herewith photos of the SBC i notice it looks diffrent than the old one...
Comments please..
Attached Thumbnails Service Brake "Visit Workshop!"-dsc00105.jpg   Service Brake "Visit Workshop!"-dsc00107.jpg   Service Brake "Visit Workshop!"-dsc00108.jpg   Service Brake "Visit Workshop!"-dsc00109.jpg   Service Brake "Visit Workshop!"-dsc00110.jpg
Old 07-06-2006, 04:53 PM
  #46
Barry45RPM's Avatar
2015 ML 350
They're going to re-flash your audio. Its amazing how hard it is to leave the shop without something else going wrong with these cars!
Old 07-06-2006, 05:04 PM
  #47
jimbo1mcm's Avatar
All Diesel Fleet !1983 240d stick,2005 E320 CDI Midnight blue, 2005 E320 CDI, Desert Silver, Kubota
Again, Worldwide MB Maintenance Training Problems
MB needs to assess its' maintenance. Maybe it is just too big a problem to keep up with sophisticated computer dominated automobiles. But they make them, so they are supposed to be able to fix them. Someone needs to take charge of maintenance. Should we do a J.D. Power maintenance survey?
Old 07-06-2006, 05:37 PM
  #48
Talbot's Avatar
If only they'd put in a USB port and make the software updates downloadable...
Old 07-06-2006, 06:53 PM
  #49
Barry45RPM's Avatar
2015 ML 350
Sounds like you are a little ticked at the stupid & second rate electronics/software. I am too. I love the way the car feels and looks, but its in the damn shop for idiotic problems far, far too often. The glow is starting to come off the vehicle's ownership experience.
Old 09-03-2014, 04:05 AM
  #50
Ragy.abuamra's Avatar
W211 E500 05'
Well, I got that exact message as well.
Took it to the dealer. They said it's the SBC High Pressure Reservoir, which is not covered by the 10 years warranty. (Only the SBC Pump is covered).
Paid 1100$ to replace the reservoir, and the message is cleared now.
I drive an E500 05' with 180k km on it.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
Quick Reply: Service Brake "Visit Workshop!"
