Where can I find sunroof rubber sliders (accordion style)
Hi everyone. I hope I can make this clear enough without any pictures (my digicam is on the fritz). On the E320 sunroof, there is a rubber accordion style piece that unfolds as the sunroof is put in the tilt position. On mine, the rubber has come apart. I tried to glue it together with superglue to no avail. Does anyone know where I can order the part (outside of the dealer) so I can replace it myself?
Many thanks!
Many thanks!
2015 ML 350
Many thanks!
Many thanks!
Received 4,415 Likes
'71 Pinto
This part is actually called a bellow and if you PM your VIN I can give you the part numbers. I assume you are out of warranty therefore, start by checking with the following sources for discounted cost and either purchase or request your local dealer to match or better the lowest quote.
Requires MBCA membership # (typically 20-25% discount)
http://www.parkplacetexas.com/SelectMB.asp
Discount retail and wholesale
http://www.calibermotors.com/site_parts.cfm
Fellow member KYBENZ
https://mbworld.org/forums/members/28130-kybenz.html
Many thanks!
Many thanks!
A211 780 11 40
A211 780 12 40
It's a ten minute job to replace both. These parts on my E500 have also come apart after 3 years of use. My local dealer quoted me $65 for each side. Drop me a line if you find them cheaper somewhere else.
Alex
'71 Pinto
Alex, good call. Part number is not VIN sensitive and therefore is used across multiple MYs and 211 models. One never knows with MB, sometimes a part has different ID numbers for various same class models yet there is no difference in the part itself.
2007 E350 > 2007 Honda Odyssey>2006 Porsche 911 S
The part you are looking for is called 'rubber bellows" or 'rubber boot' and is available from MB. Part numbers are:
A211 780 11 40
A211 780 12 40
Alex
A211 780 11 40
A211 780 12 40
Alex
'71 Pinto
MSRP $74 each, $55.50 free shipping http://www.oediscountparts.com/partl...?siteid=215242
Follow up to step 5 http://workshop-manuals.com/mercedes...up_roof_panel/ + http://workshop-manuals.com/mercedes...g/pop-up_roof/
'71 Pinto
No, without panoramic left 2157801540, right 2157801640.
Thanks in advance
'71 Pinto
gni2002 (04-06-2018)
2008 SL550 R230, 2004 E320 W211
I know this is an old thread, but I was hoping to find some better instructions on how to replace these bellows/baffles (accordion rubber on side of sun roof) on our 2004 E320. Does anyone have instructions or pictures. I did search and found some info here from 2005: https://mbworld.org/forums/e-class-w...of-baffle.html that said "pry open the plastic panel at the front of the sunroof (do it from the front, go easy, since they held into sunroof via couple plastic lock). Close the sunroof, tilt it up, and pull these two rubber piece, snap new one in, and finish the job..." Is it really that easy, does anyone have any other tips or pictures on how to do this?
Lee
Lee
Hi there. I am a new member and trying to work my way around the forums.
This is the closest related issue to a question I have. Does anyone know where I can download information on how to replace my w211 e320 bellows on my sunroof?
Thank you in advance.
'71 Pinto
Panoramic (code 413) see attachment; left part # 2117801140, right 2117801240.
Standard (414) move sliding/pop-up roof to pop-up position detach rubber bellows on both sides top and bottom to remove; 2157801540, 2157801640.
I attempted to change them today but in the front of the glass there is a plastic piece that gets in the way of the removal. Do I need to take it off as well? I only have a regular sunroof.
'71 Pinto
See lines 3-5 in attachment.
gogydm (02-01-2021)
Also, if you happen to break that part in the removal of it, it's only about $18 from the dealership so no biggie.
