red button on trunk E350 2008
2008 E350 mercedes sedan
hello newbie here, can someone help steer me to existing thread or help with my trunk only going down 1/2 way when i push red button in trunk. i have to push 2x in order for it to close.
thanks
thanks
Received 1,467 Likes
Try to normalize the system. Open and close all the windows/sunroof by holding down the buttons for at least 5 seconds after they're opened/closed. Open and close the trunk with the button on the driver's side door. If that doesn't fix it, you may have other problems.
Trunk button still not working
Thank you, I tried to normalize and still trunk only going down 1/2 from red button and requires a second push to close
Any other suggestion on how to fix?
Is the button still lit when it goes halfway down? My only other thought would be that maybe the wires are half loose. There's a bundle in the trunk that ends up getting cut and that's half the reason why it stops working. Did your battery die recently? If so, you could try disconnecting the battery and try it again. There's a thread around there that mentions how to fix the wires in the trunk. Other than that, it might be off to the dealer for you.
Trunk red button now not working
Hello
thanks for your reply!
i was not able to locate the trunk limit option in my guage
do you think my 2008 e350 sedan model may not gave this feature?
what shall I try next
thanks all -
thanks all -
