E-Class (W211) 2003-2009
DIY: Installing a new Changeover/Heater Control Valve
Rating: Thread Rating: 25 votes, 4.80 average.
Old 02-18-2015, 12:37 PM
  #226
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
[QUOTE=zambezi2;6224770]
Originally Posted by kurtwz
Are you talking about how to replace the stepper motor for the heater? If so its this thread, first page : https://mbworld.org/forums/e-class-w...rol-valve.html
Hi kurtwz,
Not sure if this is what I need to change. My problem is that the rea seats AC does not get cool air, only gets hot or room temperature air, while the front seaats AC works without a problem. Somewhere I rread that this is a problem from some dual valve situated under the front fender or mudguard. What is your opinion?
The Duo valve is located on the drivers side under the plastic cover. easy to see and get at once the cover is off.
Old 04-05-2015, 12:53 PM
  #227
Tschuss_Bill's Avatar
2005 E320 CDI
Originally Posted by Tschuss_Bill
Thanks for the part numbers.
You could call a service advisor, they might help. It's a good thing to have your car's code list.
Code 228 is the electric aux heater. It warms the interior before there is sufficient heat in the heater core.
Now I'm going to double check the part I replaced. It did not solve the problem that I was having.
Correction:
Code 228 does not related to the Electric Heater. I just compared both valves. A2118320584 was the part installed in my CDI. A2118320684 looks almost the same but it has an extra hose fitting, see I marked it with blue tape in the picture. Having now done a bit more research on option code 228 "Auxiliary Heater", this is a fuel fed heater that resides in the fender well. I cannot imagine that US bound cars had this option available.
Attached Thumbnails DIY: Installing a new Changeover/Heater Control Valve-img_2658.jpg
WalterChavez (09-09-2020)
Old 04-21-2015, 09:21 PM
  #228
S430LUCKDRAGON's Avatar
2003 S 500 4 MATIC , 2001 S 430 , 2003 ML 500
Awsome tutorial one question would it be located same place on other models ?
Old 04-27-2015, 06:52 PM
  #229
craigc's Avatar
2003 W211 Avantgarde (Sport), 2007 E550 Sport package
Thanks for the great DIY,
Did the test on pins 9 and 12 on the M4 connector of the drivers side SAM, its supposed to be around 10 ohms. Mine was 96 ohms.
Based on that I thought the driver chip on the drivers side SAM was blown so I ordered 2 because they are about $3.00 each. Turns out I didn't need them so If anyone needs them to repair their drivers side SAM I can sell them to you for cost or repair your SAM for cheap. (I've been a Electronics Technician for 25 years)
The code was 9027
I did remove the wipers, made it easy, about 45 min.
Like others I decided to open up the old valve.
The picture of the scan tool was taken after I replaced the valve so you can see the code from me disconnecting the wiper motor.
Erased the codes and rescanned the car and now have 0 faults.
Attached Thumbnails DIY: Installing a new Changeover/Heater Control Valve-img_0055.jpg   DIY: Installing a new Changeover/Heater Control Valve-img_0054.jpg
Old 05-09-2015, 03:51 PM
  #230
moehler's Avatar
2014 CLS 63 S AMG / 2004 E55 AMG
The code was 9027
Which connector is the M4 connector on the drivers side SAM, can you please post a pic?
Old 05-09-2015, 05:55 PM
  #231
craigc's Avatar
The M4 connector is one of many connectors plugged into the underneath of the Driver side SAM so you have to remove the SAM to see it or get to it. Once you have the SAM removed you'll see the M4 connector. Sorry I didnt take pictures of the connector and I tried to find one for you and found the picture attached. I cant remember for sure but I think M4 is the very bottom right connector. I've also attached the MB bulletin that talks about testing the M4 connector.
Hope that helps
Attached Thumbnails DIY: Installing a new Changeover/Heater Control Valve-driver_side_sam.jpg
File Type: pdf
Old 06-02-2015, 03:00 PM
  #232
Jeffhixson4's Avatar
Mercedes
Heater control valve
Great instructions and illustrations! However, my only problem was after installing the new valve and putting everything back together, my windshield wipers won't work. 👎
Old 06-02-2015, 11:16 PM
  #233
craigc's Avatar
I dont want to sound like a smart @%s but did you remember to reconnect the wiper motor ? Believe me its something I would do. If you did you may have to clear the code, please refer to my previous post of the description of the scan tool after I replaced the valve. I show the code for the wiper motor and the valve after I changed the valve.
Hope that helps
Old 06-02-2015, 11:20 PM
  #234
Mercedes
Hope that helps
Thank you,!!! I'll check 👍👍
Old 06-02-2015, 11:30 PM
  #235
craigc's Avatar
Your very welcome, I love these cars. The post I was refering too is post #229.
My scan tool showed code (9050 wiper motor) and (9027 heater exchange shut off motor) after I replaced the valve. This surprised me because the car was turned off during the whole valve replacement. I cleared both codes and all was well.
Old 06-30-2015, 12:16 PM
  #236
IMIEIW's Avatar
E550
Thank you, at least I know what direction to go. Went out this AM and had a passenger in the rear. He wanted to know why it was so hot back there. I guess this is one answer. As stated in some of the earlier posts, this seems to be an intermittent problem. Without a scanner, which I have to get, which one I don't know, it is hard to diagnose properly. What fuses are associated if any?
Old 07-01-2015, 09:12 AM
  #237
demoned's Avatar
mercedes w211
Hello to all!
Thank you for the excellent explanation.
I have an issue after placing the new one, it leaks and I am not able to stop the leakage on the lower entrance pipe that goes inside the car. Do i need to use special seal component in order to stop this leakage or am I doing anything wrong.
Old 07-08-2015, 07:58 PM
  #238
moehler's Avatar
I replaced the heater valve (twice) and it didn't solve my intermittently hot air from the rear vents issue... thanks to craigc, I replaced the heater valve control chip in the SAM, and it fixed the issue completely. Here's a link to my thread -
https://mbworld.org/forums/w211-amg/...trolvalve.html
Old 07-10-2015, 02:59 AM
  #239
demoned's Avatar
mercedes w211
Originally Posted by demoned
Hello to all!
Finally fixed the issue through and painful process in replacing the radiator that the valve is connected. The corrosion had damaged the radiator pipes giving no chance in sealing the leakage.
Old 07-13-2015, 10:14 PM
  #240
Cliviscus's Avatar
E320 2004 Model W211
Heater Problems
I have a RHD E320 W211 and have changed the heater control valve situated under the Brake Master Cylinder and alas much to my disappointment there is no change and I still have cold air blowing out the vents. Any ideas would be greatly appreciated.
Old 07-14-2015, 11:09 AM
  #241
demoned's Avatar
mercedes w211
The heater control valve, it is not where are you describing it. Are you sure you changed the right valve??
Old 07-14-2015, 02:03 PM
  #242
craigc's Avatar
I'm guessing he did replace the correct valve, its in a different spot than our left hand drive cars. see here
Old 07-14-2015, 02:06 PM
  #243
craigc's Avatar
Did you open up the original changeover valve to see if there was evidence of leaking and or corroded/broken pieces inside?
Old 07-14-2015, 06:59 PM
  #244
Cliviscus's Avatar
Valve under master cylinder
I believe it to be the right valve and after wiping away the many tears I actually took the car for a run and think there may have been an air lock as after a short while it started blowing hot air God bless it. Many thanks
Old 07-14-2015, 07:45 PM
  #245
Mr. CVE's Avatar
MY06 E55
Yes the RHD cars ( like mine ) the heater tap is in a spot that is almost impossible to get to !
I did mine as well, nearly killed me !
I read this post, though... easy job and bought the parts, pulled it apart and was like... how am I going to get to that !!
All good now.
Old 07-18-2015, 09:33 PM
  #246
Heatwave's Avatar
2007 E350; 2018 GLE350
Is this a heater changeover control valve problem: Occasionally my '07 E350 will quit producing a/c cool air through the control vents in the dash and in the console. It sounds like the ducts inside the dash are closed ... I can hear the a/c blower motor operating, but nothing comes out of the vents. I discovered that I can stop the car, turn off the engine, restart it, and the a/c control doors return to normal operation. Control valve?
Old 07-30-2015, 04:14 PM
  #247
sealrockswell's Avatar
2003 Mercedes-Benz W211 E55 AMG
Thank you so much W211 Ryda. This tutorial was perfect and resolved the unbearable heat issue. I too live in SoCal and this was really killing me this summer. WHat part of SoCal are you from?
Old 08-05-2015, 12:29 AM
  #248
abu bakar's Avatar
E240(211)
nice job brother DIY
Old 08-05-2015, 06:53 AM
  #249
Cliviscus's Avatar
Replacement Costs
All good now.
Interesting to note that when I took it to my normal service agent he suggested I left it with him for a day to diagnose. Returned to pick it up said he was waiting on an email before quoting me. I said so you need a photo of the part so then you can locate it and we both shared a laugh. After some great advice from this forum and not disclosing it to this guy returned to get my quote which was $400.00 AUD for the part and 8 hours labour. I phoned the local dealer who quoted me $158.00 AUD, I then phoned a supplier in Melbourne who imports his own parts $126.00 AUD with overnight delivery included and it took me approximately 3 hours plus a reasonable amount of skin and blood loss.
Many thanks guys for your valuable advice
Old 09-03-2015, 10:54 AM
  #250
IMIEIW's Avatar
E550
Thanks so much for the pictures and advise. I was lucky and only broke 1 clip. Job went well and now we're hanging meat.
Jkm50966 (10-29-2022)
You have already rated this thread Rating: Thread Rating: 25 votes, 4.80 average.
Quick Reply: DIY: Installing a new Changeover/Heater Control Valve
