COMAND HEAD UNIT software update to enable MP3
#251
#255
#256
Help req
E500 2004 Japanese spec
I have same problem here the command system unit build in Japan and it is completely different
Please help me to know:
1- how can get to the engineering mode?
2-there is some after market command unit in the market but if you want to change it you have to bypass amplifier and I don't want to do that.I heard there is a small box that you can connect fiber optic to that and keep the amp in your system.
Any body know? I heard it is like convert or or adaptor between after market command unit and amplifier .
Tanx
Tanx
#257
Tanx
Tanx
#258
Changing language for map,what about bypass amplifier ? Do you know any device to keep amplifier in changing head unit because the after market head unit not support fiber optic but I heard there a box to connect head unit and amplifier together wires from head unit and fiber optic from amp connect to it and it is work and connect both together
#260
I have a 2007 S211 Mercedes manufactured in Germany for European market(AFAIK, my COMAND head unit is manufactured by Becker). Am I correct that my current firmware version is 30/06? According to "SW Ver.HU" field in engineering menu it looks like so:
While I have the Mercedes Service CD version "W211 589 14 22 00", I have heard that there are even newer versions available like "W211 589 15 22 00" or "W211 589 16 22 00". What is updated in those newer releases compared to "W211 589 14 22 00"? Does anybody have access to those newer firmware versions?
#262
Nice Am I correct that one can get the 28/2008 COMAND HU software with Mercedes Service CD version "W211 589 16 22 00"? In addition, are you able to use newer navigation maps with your 28/2008 release compared to 46/2006? Or in general, what are the advantages of non-official 28/2008 release compared to well-known 46/2006 release? Are there any disadvantages?
#264
Originally Posted by starbrite
There's also W211 589 15 22 00, which updates the nav processor so that newer maps will work.
In addition, did you mean that 30/06 doesn't have mp3 playback and no ETO info while 46/06 does? I mean 46/06 should be later release than 30/06.
#265
I wrote it on my iPhone and made a mistake. 15/04 and 17/04 and even 40/06 are without ETA display and mp3 playback. 30/06 and up incl. 46/06 have the 2 features. All updates after 30/06 have bug fixes only. No new features. The last official update also fixes and adds new Satellite Radio Channels.
#266
#267
COMAND is COMAND and gets updated with its own update CD through the single slot drive. Maps DVD goes inside the nav processor in the trunk. Each map DVD has a firmware update on board. Once you insert a newer map DVD an update check starts to determine whether the nav processor needs an update or not. You can see this by looking at your COMAND screen. You will see two progress bars moving. If they only move a little bit no update is needed and it exits the update routine.
There are DVDs for different car models. You have to make sure it's compatible with your E-Class. That's all.
#269
Received 4,415 Likes
'71 Pinto
PM = Private Mail, click on Mackhack -> then “Send a private message to Mackhack”
#270
hi
whats the latest software update available for a US 2007 e350?
can someone pm me link for a download?
the current version is shown below
#271
Good evening everyone,
I am quite new to this so don't know where to get the updates from. Can anyone please post the download links to
W211 589 14 22 00
W211 589 15 22 00
W211 589 16 22 00
and also how can we check what version is installed already onto our Command system.
Some say, for UK/Europe we cannot get 589 16 or 589 15 but only 589 13. Is this true? Some also saying we need to get into Engineering mode on the unit, how do we do that please?
my car is E320 March 2005, UK.
Regards
J
W211 589 14 22 00
W211 589 15 22 00
W211 589 16 22 00
Regards
J
#272
W211 589 14 22 00
W211 589 15 22 00
W211 589 16 22 00
Regards
J
W211 589 14 22 00
W211 589 15 22 00
W211 589 16 22 00
Regards
J
#275
Hit SERV. If you see one car you might want to update. If you see 2 cars you're good. No matter what version is installed if you see 2 cars there is no need to update honestly. They all contain only bug fixes except the latest one. This one only has an updated Sirius Channel list that might be necessary if you have SDAR.
