Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W211)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
E-Class (W211) 2003-2009
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-10-2012, 03:59 AM   #101
Drives: 03 e500 Sport w211
Thank you I did try them several times - I'm going tfind out if the big face until is a plug and play into my car and search for it - I enjoy the stock head unti look and I'm sure thatll solve my issues
To remove this ad, register today or login if you already are registered!
MPOW33R is offline   Reply With Quote
Old 05-10-2012, 04:03 AM   #102
Thank you I did try them several times - I'm going tfind out if the big face unit is a plug and play into my car and search for it - I enjoy the stock head unit n I would like mp3 and the full screen look and I'm sure thatll solve my issues
Old 05-10-2012, 04:14 AM   #103
Mackhack's Avatar
Drives: 2004 W211 E320
Send a message via Skype™ to Mackhack
If you have audio50 it is plug and play bc you have the AGW in the trunk. If you have the audio20 there is more to it.
Mackhack is offline   Reply With Quote
Old 05-10-2012, 04:19 AM   #104
How do I find out which one I have and what is AGW? A little new to this as I've only had the car 5 days now and have just been ordering parts and parts yet the sound system is in the works now !! So I appreciate any tips
Old 05-10-2012, 12:03 PM   #105
Mackhack's Avatar
Audio Gateway. It's the master device and amplifier within your MOST ring.
Old 05-11-2012, 03:14 AM   #106
Drives: E270
Quote:
Originally Posted by dewana421 View Post
Mercedes COMAND HEAD UNIT Service CD W211 589 14 22 00
This is for 2003-2006 models with command unit.might also work for 2007-2009 yr model
use google
Use this CD to update the COMAND Head Unit to software version 46/06.
Unzip the archive and burn all of the files onto a regular CD-R disc, making sure that your software finalizes the disk when it's done. I use NERO, and on NERO it is listed under the "burn" tab on the verification screen just before the CD starts burning.
Once you have the CD, power up your COMAND unit, briefly hold down 1,3,8 at the same time, and the service screen should come up asking you to insert the CD. Insert the CD and the update will begin automatically. VERY IMPORTANT....DO NOT CHANGE SETTINGS OR TURN IGNITION ON OR OFF DURING THE UPDATE PROCESS.
Once the CD is done updating, it will eject the CD and the COMAND unit will restart itself. That's all there is to it.
My unit is a 2005 version, and I cannot attest to weather this will work in other versions, but I have read that it will work on all COMAND units.
If you do not have the Nav module, then this should still update your audio SW... but only if you have the COMAND Head Unit (the one with the large screen). If you have the smaller unit, I think it's called the Audio 50 (but don't quote me on that), then I don't think this will work for you.
Also, this IS NOT a map disc. This is simply the SW update for the COMAND system itself. This update will add a few features with the Navigation module (i.e., adds the ability to display ETA at the bottom of NAV screen) if you have it installed, but it also updates other audio items as well, like the ability to play MP3 discs.
Link no longger available. Anyone able to sent me link to downoad.
nizam9w2ms@gmail.com
Thank you
nizam9w2ms is offline   Reply With Quote
Old 05-15-2012, 05:51 AM   #107
Drives: e350
download link
Great info! Please PM or email the download link
Thank you
Kevin
kevin@sickles.net
kevinsickles is offline   Reply With Quote
Old 05-20-2012, 11:48 PM   #108
Drives: 2003 e500 sport
2003 update head unit
i have the navi. screen unit in 2003 e500. could someone please email me: adriagredano@gmail.com the download link.. thanx in advance..
i also could never find the aux input in the glove box.. any help ill appreciate it..
e500sport03 is offline   Reply With Quote
Old 05-21-2012, 12:08 AM   #109
Mackhack's Avatar
Aux is on top at the front middle.
Old 05-21-2012, 11:58 AM   #110
nizzle's Avatar
Drives: 04 MB E55 AMG (MINE); 06 Jag XK8 Victory Edition Vert (HERS); 1997 Pontiac Sunfire (work mobile)
Quote:
^this
__________________
nizzle is offline   Reply With Quote
Old 05-21-2012, 12:07 PM   #111
Mackhack's Avatar
Here is a picture showing it (front upper edge): Click the image to open in full size.
__________________
Mackhack
[x] Limo Dark Window Tint
[x] Bluetooth Puck
[x] Euro COMAND/DVD Navigation (527)
[x] UPsolut ECU Tuning
[x] iPod Integ. Kit (057)
[x] Power Folding Mirrors (500)
[x] THERMOTRONIC (581)
[x] Linguatronic (396)
[x] Interior Motion Sensor (882)
[x] 12V Aux Socket in Trunk (Y763)
[x] Distronic (219)
[x] Digital/Analog TV Tuner (863)
[x] Power Trunk Closer (881)
[x] Ill. Door Sills
http://www.mbretrofits.com
Old 05-21-2012, 03:36 PM   #112
Drives: 2005 E320 CDI
Kindly message me the link! Thanks.
-Bill
Tschuss_Bill is offline   Reply With Quote
Old 05-22-2012, 03:10 PM   #113
Drives: Mercedes Benz E320 W211 2004
HERE THE LINK
https://www.dropbox.com/s/mgojhwm43fi84ao/US4006.zip
samo1 is offline   Reply With Quote
Old 07-04-2012, 08:36 PM   #114
IT WORKED !!! HERE IS HOW
BURN THIS IN 6X OR SLOWER
CAR WAS "ON" ENGINE RUNNING.. (do not touch key until competed)
TURNED HEAD UNIT ON--> (I was in FM radio mode and just turned the volume all the way down)
HOLD DOWN 1,3,8 @ the same time AND
ON THE SCREEN ITS SHOULD SAY - INSERT DISC
I INSERTED DISC AND IT STARTING TO UPGRADE
IT SHOWS 2 VISUAL PROGRESS BARS AND SAYS
FLASH AND REFLASH AND THEN SAID
RESTARTING UNIT IN 3,2,1 AND RADIO SHUT OFF THEN ON
DONE - TOOK ABOUT 6-8 MIN
IT SAVED ALL MY PRESETS BUT RESET MY EQUALIZERS
NOW THE CD DRIVE IN THE HEAD UNIT ITSELF PLAYS
DVDs with MP3 Folders and MP3 Cds.
I FEEL MY MY SUB SOUNDS BETTER, I USE THE LOGIC MODE
FUGGIN AMAZING
*** WILL NOT PLAY MP3 OR DVD FROM CDC ( cd changer)
and I dont care
Old 07-13-2012, 03:37 AM   #115
Drives: 2004 E320
I just finished this update...
1) No MP3 in CD6 (my W211 was built in 10/03)
2) It erased all of my radio presets, as well as all of my VCS data (really annoying!)
3) No more access to the Engineering Mode with the previous method (Is there a "new" key sequence that works?)
4) The CD slot in the COMAND no longer loads discs. I think this is a coincidental failure, as the update CD barely loaded, and was very slow to eject.
So, what's it gonna take to fix the loading motor on the CD slot?
KevinD
KevinD is offline   Reply With Quote
Old 07-13-2012, 10:02 AM   #116
MercFiveHundred's Avatar
Drives: 2003 E500 Pewter/Black, 1997 E320 Black/Tan
FUGGIN AMAZING
and I dont care
Wait, the update worked for the non-nav/small screen cassette unit?
MercFiveHundred is offline   Reply With Quote
Old 07-13-2012, 10:58 AM   #117
Mackhack's Avatar
KevinD
Kevin,
2.) That is normal If you updated to firmware version 30/06 then yes no more EM access. They changed the key sequence to get in, and they also changed the key sequence for the Driver Distraction menu within EM.
3.) Normal as well that it erases the station presets - unfort. But the good thing is you don't have to update your COMAND as often as your Windows PC
4.) you're talking about COMAND, so I assume you have the COMAND APS (NTG1). If the motor fails and/or CDs/DVDs don't get read anymore you most likely need a new drive. If you need a new drive, PM me as I would need some information from your COMAND because over the years Harman/Becker used different drives and if it doesn't match the one you have now it might not play/work right. You can compare that with a tire and a rim. The tire will work on a rim but if the wheel is not balanced it just doesn't work right.
__________________
Mackhack
[x] Bluetooth Puck
[x] Distronic (219)
[x] Ill. Door Sills
Old 07-13-2012, 02:30 PM   #118
gaazmon's Avatar
Drives: 2008 CLK550 Obsidian Black Metallic, Black Leather
WILL NOT PLAY MP3 OR DVD FROM CDC (cd changer)
yup it won't. MY05 the CD changer became MP3 capable (MY09 it became a DVD changer). However, starting MY05, the COMAND didn't come with the secret DVD drive anymore so u still get more music on 1 DVD-R vs 6 CD-R's
has anyone else confirmed if dual layer DVD-R's work? and also do DVD+ work with this?
__________________
2008 CLK550 - Obsidian Black Metallic, Black Leather
Options:
Premium 2 Package (Bi-Xenon Active Light System With Cornering Fog Lamps, Glass Sunroof, Harman/Kardon Sound System, 6-Disc CD Changer, Auto Dimming Driver And Rear View Mirrors, Garage Door Opener)
DVD Navigation
Keyless Go
Heated Front Seats
Rear Side Air Bags
Sirius Satellite Radio
Electronic Trunk Closer
Burl Walnut Wood Shifter
Mods:
DEPO Clear Side Markers
SunTek Tints: 30 Sides 15 Back
gaazmon is offline   Reply With Quote
Old 07-13-2012, 02:39 PM   #119
Mackhack's Avatar
My HU has a Dual-Layer DVD/CD ROM drive. It works like a charm DVD+/- both work with the unit. However DVD-R are usually the better choice (not just for the HU) btw.
My car is a 2004 and CDC also plays mp3's.
__________________
Mackhack
[x] Bluetooth Puck
[x] Distronic (219)
[x] Ill. Door Sills
Old 07-13-2012, 09:57 PM   #120
gaazmon's Avatar
Good to know
Just tried on mine. CDC won't read MP3 CD
__________________
Options:
DVD Navigation
Keyless Go
Heated Front Seats
Rear Side Air Bags
Mods:
Old 10-15-2012, 11:21 AM   #121
Drives: 2006
thanks bro
fahadrj is offline   Reply With Quote
Old 10-30-2012, 10:23 PM   #122
Drives: MERCEDES 2004 E 320
FUGGIN AMAZING
and I dont care
two questions. did you burn your cd as data cd or as ISO
also, can you now see song info, like title, and artist and song name
ASHBURY04 is offline   Reply With Quote
Old 10-30-2012, 11:39 PM   #123
Mackhack's Avatar
Once your COMAND accepts mp3 files you can burn them as "Data" instead "Audio". A regular CD can contain about 21 songs each 3 minutes average. If you burn them as Data you can put about 180 songs on it.
I use Dual Layer DVDs (9 GB) with folder structure => Awesome
__________________
Mackhack
[x] Bluetooth Puck
[x] Distronic (219)
[x] Ill. Door Sills
Old 11-01-2012, 12:08 PM   #124
vanboy's Avatar
Drives: E55 2004
How can i access the engenering menu after upgrade?
I upgraded my Comand, with file of
All Ok,
but i cant use the Mute + Phone_End + Serv for access the engeneering menu, as befor.
As any update to see DVD video on US comand?
Thx
vanboy is offline   Reply With Quote
Old 11-01-2012, 12:19 PM   #125
Mackhack's Avatar
Not possible because US COMAND don't have DVD encoder micro processor in. Only ECE COMAND and first batch of US COMAND have it.
Engineering menu code has changed as well as DR.DIST menu code.
Tags
2006, 4606, cd, comand, crossbar, e320, e350, head, mercedes, sedan, software, unit, update, updated, version, w211, wagon
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
