E-Class (W211) 2003-2009
Car sputters and almost stalls
Old 05-09-2010, 12:36 AM
MB_04E500's Avatar
2004 E500 RWD
Hey guys long time reader first time poster. haha 2004 E500 RWD 89k miles
I really need some help. i had a problem a while back that whenever slowing down to a stop sign or light the car would sputter and almost stall when stopped. a few time all the dash lights would come on and the go back off and the car would operate normally. since it only happened a few times i didnt think to get it to the mechanic right away. then one unfortunate night while at a stop light it did the same thing but i also couldn't accelerate in comfort mode so i put it in standard mode and got it to the mechanic..long story short they ended up replacing the tranny with a rebuilt one. prob went away..fast fwd a few mos later it happened again i took the mech for a ride and he said its dropping cylinders so he replaced the plugs and the MAF. everything seemed OK after that. but now its starting to do the same thing AGAIN!!! also when trying to pass ppl on the highway at about 60mph and 3500 RPM's the car starts to jerk and when i let off the gas and press the gas it starts working fine again. please help any ideas would be helpful, ive searched everywhere with no luck
hope this is enough info if you need more just let me know
Old 05-09-2010, 02:22 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
I'm confused so does the car still sputter and/or stall when coming to a stop? Did they check for a vacuum leak?
Old 05-09-2010, 03:28 PM
MB_04E500's Avatar
2004 E500 RWD
Yeah the car still does but only when coming to a stop. as far as i know they did not specifically check for a leak i can only assume now that he would have done a full inspection but you never know
Old 05-09-2010, 03:46 PM
2MCHCAR's Avatar
Supercharged CLK500 & ML500
+1. My CLK500 had a similar problem after they changed the valve cover gaskets. It ended up being a vacuum leak on a hose coming from driver side valve cover.
Old 05-09-2010, 03:55 PM
MB_04E500's Avatar
2004 E500 RWD
Ha just had the valve cover gaskets changed too hope they look for stuff like that.
Old 05-10-2010, 03:47 PM
Former Vendor of MBWorld
E92-Lighting's Avatar
BBS LM's 18's + Kics
it could be a vacuum leak
Old 05-10-2010, 08:23 PM
MB_04E500's Avatar
2004 E500 RWD
anything else
is there anything else anyone could think of to check. I'll look into the vacuum leak thanks
Old 05-11-2010, 11:53 PM
tashakes's Avatar
2007 A8L 4.2
Crankshaft Position Sensor (CPS)? I just replaced mine, car would stall sometimes, would crank and not start for a while, then it would start after 10-15 minutes. Most times a CEL (Check Engine Light) would go off, then disappear and all would be good for a couple of days.
Not exactly your symptoms, but close, you can try it, it is a $40 fix, its worth a shot.
Old 05-16-2010, 03:34 PM
M.leonard2's Avatar
2004 E320 4matic, 12' 300, 95' Deville(RIP)
My dad just Had this problem at the same mileage as yours. Problem was with the injectors needed cleaning and bad gas. the indy Cleaned all injectors and and drained fuel lines and tank
Old 05-17-2010, 08:29 AM
vettdvr's Avatar
03 E500 and Corvette
You might consider reading the OBDII codes to give you a small clue.
Old 05-17-2010, 08:09 PM
MB_04E500's Avatar
2004 E500 RWD
Thanks, is there a brand of fuel injector cleaner that actually works? Which do you guys recommend? And i use nothing but chevron gas.
Also the indy mech said no codes were being thrown.
Old 05-18-2010, 10:50 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
None of those actually work -- the proper way to clean fuel injectors is to either remove them and put them into a bench-top machine designed for that, or use a cleaning cannister that hooks up to the fuel rail and delivers a cleaner solution -- this runs on shop air and I would assume that your indy mechanic has one already -- they're only about $150 + $15 for a can of cleaner. This is the easiest way to clean the injectors. Also, was the fuel pressure and volume tested at the rails?
Regards,
paul...
Old 05-18-2010, 10:13 PM
M.leonard2's Avatar
[quote=MB_04E500;4078621]Thanks, is there a brand of fuel injector cleaner that actually works? Which do you guys recommend? And i use nothing but chevron gas.
I don't know how he did it but i know he took them off clean (with what and how idk) them
Old 05-19-2010, 07:21 AM
paulv's Avatar
There's a guy who posted this to youtube (http://www.youtube.com/watch?v=VFJlTfHyrUk) where he took the injectors off and rigged up a cleaning system -- this is great assuming that the injectors are easily accessible.
Regards,
paul...
Old 05-20-2010, 02:27 PM
vettdvr's Avatar
I helped a neighbor this weekend with his truck. Stalling no power. No codes. We pulled the MAF he cleaned it and replace the aircleaner. It ran ok after that and all was normal. The (his was really fouled) plugged aircleaner allowing dirt to reach the maf was causing his problem. He is now 1000 miles into the clean up and all is well. The way I confirmed on the truck was to unplug the maf with engine running to force failsafe. Then all was pulled and cleaned.
BTW from what I have found Chevron Techron is the only MB approved injector additive. You might try it in the "High Dose Cleanout Ratio" before pulling the injectors.
Quick Reply: Car sputters and almost stalls
